July 8, 20206 yr 1 hour ago, Hyaenidae said: Ah,.. well, @Hyaenidaeย looks like the engine bay could use a clean up. I usually vacuum clean the bay.ย Luckily my engine cover is large enough so that it covers a wide area
July 8, 20206 yr 7 minutes ago, K.o.N.o.S said: @Hyaenidaeย looks like the engine bay could use a clean up. I usually vacuum clean the bay.ย Luckily my engine cover is large enough so that it covers a wide area How come your air vent have a rubber hose? I don't have that. Where does it lead? ย Edited July 8, 20206 yr by Hyaenidae
July 8, 20206 yr Author 10 hours ago, Hyaenidae said: How come your air vent have a rubber hose? I don't have that. Where does it lead? ย Its not there in my car as well.ย
July 8, 20206 yr Author 12 hours ago, Hyaenidae said: Ah,.. well, ย On the plus side, the coolant reservoir tank is clean(er) now! You can see if the coolant is discolored without evenย removing the cap, that little blue bit is coolant.ย ย Man that looks like an engine bay of a barn fine. At least use compressed air to remove that dirt.ย
July 8, 20206 yr On 6/28/2020 at 6:21 AM, Davy said: That shine! ?ย ย 22 minutes ago, trinity said: Man that looks like an engine bay of a barn fine.ย
July 8, 20206 yr 32 minutes ago, trinity said: Its not there in my car as well.ย No airbags, we die like real men NO EPS, I turn the steering wheel like a real manย ย ???? Edited July 8, 20206 yr by Hyaenidae
July 8, 20206 yr Author 39 minutes ago, Hyaenidae said: No airbags, we die like real men NO EPS, I turn the steering wheel like a real manย ย ???? Ha ha on the plus side, you have few additional horses ? than me at your disposal...ย
July 8, 20206 yr 12 hours ago, Hyaenidae said: How come your air vent have a rubber hose? I don't have that. Where does it lead? It leads to no manโs land. ?? can you guess where does it lead to?
July 8, 20206 yr 1 hour ago, trinity said: Ha ha on the plus side, you have few additional horses ? than me at your disposal...ย And some more torque, plus a slightly different exhaust 15 minutes ago, K.o.N.o.S said: It leads to no manโs land. ?? can you guess where does it lead to? I'd guess nowhere, it just hangs out?ย I thought it's a quirk of the 4A91 engine but Trinity's 4A91 doesn't have it. It doesn't even have a part number ย ย ย Edited July 8, 20206 yr by Hyaenidae
July 8, 20206 yr 4 hours ago, Hyaenidae said: No airbags, we die like real men NO EPS, I turn the steering wheel like a real manย ย ???? Clearly not married then... ย
July 9, 20206 yr 15 hours ago, Kavvz said: Clearly not married then... ย I said "turn", not lift twist and jerk ?
July 18, 20206 yr ย On 3/15/2020 at 11:01 AM, Hyaenidae said: One of my strut boots is in tatters. Mitsubishi, you should work on the quality of your rubber! it only lasted 5 years! But to be fair the roads I travel on are quite bad since there are considerably long stretches of road still under construction. ย A pair of strut boots costs Rs. 7400/- at the agent, can order a pair online for Rs. 4k -5.5k. Gonna go the online route obviously. Will keep you guys updated. Edit: Ordered a set from amayama.com ย On 4/22/2020 at 9:55 AM, Hyaenidae said: Look at that booty!ย No taxes, delivered to the doorstepย I thought I had posted a follow-up to this before I posted about the coolant change but apparently I haven't; so here goes: The before: ย And after: ย ย Here's how it's done, this is the best video I could find which describesย the process. It took about 2.5-3 hours for two technicians to replace both boots at the agent: ย ย Cost breakdown: Parts: 2 x Shock boots (OEM part number:ย 4060A532, FEBEST part number:ย MSHBCU20F, sourced from amayama.com) Rs. 5040.00 Labour w/tax @ the authorized agent: Rs. 5960.00 Wheel alignment check: Rs. 1200.00 Totalย Cost: Rs. 12,200 Remarks: This wouldn't be aย necessary repair if your shock absorbers are nearing the end of theirย life expectancy (about 100k I reckon) decided to get it done because I'm yet to hit half of that mileage and to avoid the risk of premature failure caused by dust/debris getting inside. ย Edited July 18, 20206 yr by Hyaenidae
July 18, 20206 yr 48 minutes ago, Hyaenidae said: ย ย I thought I had posted a follow-up to this before I posted about the coolant change but apparently I haven't; so here goes: The before: ย And after: ย ย Here's how it's done, this is the best video I could find which describesย the process. It took about 2.5-3 hours for two technicians to replace both boots at the agent: ย ย Cost breakdown: Parts: 2 x Shock boots (OEM part number:ย 4060A532, FEBEST part number:ย MSHBCU20F, sourced from amayama.com) Rs. 5040.00 Labour w/tax @ the authorized agent: Rs. 5960.00 Wheel alignment check: Rs. 1200.00 Totalย Cost: Rs. 12,200 Remarks: This wouldn't be aย necessary repair if your shock absorbers are nearing the end of theirย life expectancy (about 100k I reckon) decided to get it done because I'm yet to hit half of that mileage and to avoid the risk of premature failure caused by dust/debris getting inside. ย Nice.. I am curious to know the price of the genuine strut bootย at the agent
July 18, 20206 yr 10 minutes ago, K.o.N.o.S said: Nice.. I am curious to know the price of the genuine strut bootย at the agent 3700.00 per boot, so 7400.00 for 2 boots
July 18, 20206 yr Author 2 hours ago, Hyaenidae said: ย ย I thought I had posted a follow-up to this before I posted about the coolant change but apparently I haven't; so here goes: The before: ย And after: ย ย Here's how it's done, this is the best video I could find which describesย the process. It took about 2.5-3 hours for two technicians to replace both boots at the agent: ย ย Cost breakdown: Parts: 2 x Shock boots (OEM part number:ย 4060A532, FEBEST part number:ย MSHBCU20F, sourced from amayama.com) Rs. 5040.00 Labour w/tax @ the authorized agent: Rs. 5960.00 Wheel alignment check: Rs. 1200.00 Totalย Cost: Rs. 12,200 Remarks: This wouldn't be aย necessary repair if your shock absorbers are nearing the end of theirย life expectancy (about 100k I reckon) decided to get it done because I'm yet to hit half of that mileage and to avoid the risk of premature failure caused by dust/debris getting inside. ย Surprised to hear that agent worked with parts bought from outside. How did you manage that with them?ย
July 18, 20206 yr 12 minutes ago, trinity said: Surprised to hear that agent worked with parts bought from outside. How did you manage that with them?ย Well they did mention that I brought the part from elsewhere in the bill Apart from that there were no complications. UNIMO rocks! 10/10 will use their service again
July 26, 20206 yr So I have been hearing a rattling noise from the left side of the steering and I checked with my trusted mechanic who confirmed that the voice is definitely from the Rack end.Needless to say I was not fully convinced at his conclusion and we decided to tear the suspension apart and investigate further. In the meantime I checked with unimo who quoted 26k for both rack ends. (Hmmm bit exorbitant). Upon further checking the suspension it was noticed that Left lower control arm bush was tattered in half and there were tons of play on left link stabilizer bar. both my self and the mechanic were surprised to learn that both rack ends and tie Rod ends were in very good condition and there was no play whatsoever. Just out of curiosity I checked the prices of stabilizer bars with Unimo and they quoted 30k for both stabilizers. (Seriously unimo?) I didnโt even bother to check the lower arm bushing prices. Time to hunt for parts.ย I roamed around Kandy and went for a place recommended by a fellow civic owner. This place is called Auto traders (they are suspension experts and Famously known as "dunu kade" in Kandy) both link stabilizers were available there and quoted 3400 for both. even the exact bushes were available with them and they did the re bushing for both left and right lower arms. I got the parts back to the garage and the Job was done. Ride is pretty much smooth now. However I could still hear a bit of a noise from the steering when I am on uneven roads. As per my mechanicโs advice I am going to revisit the steering rack and probably do some re-bushing and re-greasing which I will be doing in the coming weeks. Oh and finally wheel alignment was done. Cost Breakdown. Link Stabilizer bars (2) = Rs 3380.00 Arm Bushes (2) =Rs 3500.00 Service charge (for Re bushing)= Rs 300.00 Service charge ( for Garage)=Rs 2000.00 Wheel alignment- Rs 1500.00 ย ย
July 26, 20206 yr 13 hours ago, K.o.N.o.S said: So I have been hearing a rattling noise from the left side of the steering and I checked with my trusted mechanic who confirmed that the voice is definitely from the Rack end.Needless to say I was not fully convinced at his conclusion and we decided to tear the suspension apart and investigate further. In the meantime I checked with unimo who quoted 26k for both rack ends. (Hmmm bit exorbitant). Upon further checking the suspension it was noticed that Left lower control arm bush was tattered in half and there were tons of play on left link stabilizer bar. both my self and the mechanic were surprised to learn that both rack ends and tie Rod ends were in very good condition and there was no play whatsoever. Just out of curiosity I checked the prices of stabilizer bars with Unimo and they quoted 30k for both stabilizers. (Seriously unimo?) I didnโt even bother to check the lower arm bushing prices. Time to hunt for parts.ย I roamed around Kandy and went for a place recommended by a fellow civic owner. This place is called Auto traders (they are suspension experts and Famously known as "dunu kade" in Kandy) both link stabilizers were available there and quoted 3400 for both. even the exact bushes were available with them and they did the re bushing for both left and right lower arms. I got the parts back to the garage and the Job was done. Ride is pretty much smooth now. However I could still hear a bit of a noise from the steering when I am on uneven roads. As per my mechanicโs advice I am going to revisit the steering rack and probably do some re-bushing and re-greasing which I will be doing in the coming weeks. Oh and finally wheel alignment was done. Cost Breakdown. Link Stabilizer bars (2) = Rs 3380.00 Arm Bushes (2) =Rs 3500.00 Service charge (for Re bushing)= Rs 300.00 Service charge ( for Garage)=Rs 2000.00 Wheel alignment- Rs 1500.00 ย ย ย ย ย Does Mitsubishi sell just the bushing ? Most manufacturers do not sell just the bushing (for most of their cars) and you have to buy the entire arm. The reasoning is that rebushing simply does not last that long even with the manufacturer replacement part. As for stab links being 30K....In Japan a link for a Galant Fortis part cost a bit over 4500yen (each) last year. It is interesting that the part is literally 100% more (considering it comes from Thailand, in bulk and even with shipping...that is a pretty hefty markup). Are the links you bought any known brand ? If i remember the 555 ones were in the mid 3000yen range.
July 27, 20206 yr 2 hours ago, iRage said: Does Mitsubishi sell just the bushing ? Most manufacturers do not sell just the bushing (for most of their cars) and you have to buy the entire arm. The reasoning is that rebushing simply does not last that long even with the manufacturer replacement part. As for stab links being 30K....In Japan a link for a Galant Fortis part cost a bit over 4500yen (each) last year. It is interesting that the part is literally 100% more (considering it comes from Thailand, in bulk and even with shipping...that is a pretty hefty markup). Are the links you bought any known brand ? If i remember the 555 ones were in the mid 3000yen range. They don't, you have to buy the whole armย assembly (which literally costs an arm compared to re-bushing) Part number :ย 4013A429 Costs about 30k w/shipping at amayama.com The OEM stabilizer link could be bought for Rs. 12k @ amayama.com.ย 555 brand stabilizer link costs about 5k. (including shipping costs) Part number :ย MN101368 ย Edited July 27, 20206 yr by Hyaenidae
July 27, 20206 yr 3 hours ago, iRage said: Does Mitsubishi sell just the bushing ? ย 49 minutes ago, Hyaenidae said: They don't, you have to buy the whole armย assembly (which literally costs an arm compared to re-bushing) When I inquired on the stabilizer bars from Unimo they also mentioned that arm bushes can be bought separately. They did not have them at stock and didnโt quote a price. So I didnโt bother. The stabilizer barsย that I bought were from a Chinese brand called โFrotisโ
July 27, 20206 yr 49 minutes ago, K.o.N.o.S said: ย When I inquired on the stabilizer bars from Unimo they also mentioned that arm bushes can be bought separately. But the bushing itself doesn't even have a part number, only the arm assembly does ?
July 27, 20206 yr 22 minutes ago, Hyaenidae said: But the bushing itself doesn't even have a part number, only the arm assembly does ? What about this? ย
July 27, 20206 yr 18 minutes ago, K.o.N.o.S said: What about this? ย I stand corrected. Can't belive I missed it in the catalogue ? since the ASX and the Lancer EX shares the same suspension this part should work for the Lancer too. What was the brand you bought? 555?
July 27, 20206 yr 3 hours ago, K.o.N.o.S said: ย When I inquired on the stabilizer bars from Unimo they also mentioned that arm bushes can be bought separately. They did not have them at stock and didnโt quote a price. So I didnโt bother. The stabilizer barsย that I bought were from a Chinese brand called โFrotisโ Mitsubishi is one of the very few Japanese brands to do this in that case. They seem to be doing a lot with parts (like having the budget line and standard lines). Probably has a lot to do with the Thai production base and the markets they reach to. I just checked the parts catalog for the Galant Fortis and that part number is not shown on the diagrams...it shows as s eperate part going in to the arm but braketed as one whole unit for the part number. So maybe for them it has to do something with the market as well ? For example, when labor costs are about 4000-5000 yen per hour at a dealership on average....I suppose it makes no sense to sell it seperately.
