Restoring a Toyota Sprinter Trueno
  • Author
You think ยฃ500 for a used set is a steel or one for ยฃ500 is a steal? I'm obviously quoting GBP here. They were RX8 types (you know 8 spoke alloy, not a mag versions)
I'm used to carcases. I have a couple lying around :)
I meant 500GBP for a set was a steal considering one brand new R-type aluminium wheel was/is about 45000yen and t(about 300GBP?) he magnesium one about 65,000yen (450GBP ??)plus taxes on average. Actually, having converted the 500GBP, I am not sure...when I was looking I can recall seeing magnesium sets running at around 90,000yen on average and the aluminium ones for about 50.000yen on avg. Every now and then you see individuals stripping their cars at home which are being sold at really really low prices.
  • Replies 77
  • Views 36.6k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • so this would be the start point for me.... which..thanks to the previous owner go to from this point... which considering was 26 years old at the time is still in pretty good nick...and most im
  • Whilst I was away, my dad decided to install the side strips...sadly it is at a higher level than it should be so need to refit it... The ECU was dangling at the back of the center co
  • iRage.....there is a disconnected fan wire of the RH side electric fan. It was too much electric load as I was not pushing the car. If you connect that there should be enough cooling. Check whether t
Posted Images
Yeah by the time it gets here the value sky rockets (ยฃ500 for one brand new or ยฃ500 for a used set). To be honest if somebody can export these from Japan direct and ship them to SL, whole of Sri Lankan car nuts will worship that purpose forever more.
  • 2 months later...
Any updates on this build? Photos would be nice :smilie_liebe9::smilie_liebe9::smilie_liebe9::smilie_liebe9:
I wish there were drastic updates....I am dealing with the frustrations of taking of layers of cataloy (the bottom half of the car has it quite thick) and the tinkering baas disappearing for days and days and days and days after cleaning up each panel.
This seems to be a common quality of tinkers. Maybe they work in multiple places and take on small jobs that pay them more.
But still... It's golden to find something that's in original condition :yahoo:
Any idea about the difference between an AE91 and an AE92?? :speechless-smiley-019::speechless-smiley-019:
  • Author
Yes..thankfully the previous owner had done a good job bringing it back to what it was thus saving me from additional frustration; and from the old pics I got from him it doesn't seem to have been raped before that either :)
The 90 series was the first time the Levin/Trueno went FF. Basically the AE92 was the sportier version and the AE91 the standard econo coupe' version.The AE92 came with a 4A-GE or 4A-GZE engine, had bigger brakes, discs all around and I believe TEMS was standard in all the AE92 grades.
The AE91 on the other hand came with the 5A-FE engine (108 ? or something HP). The later versions came with the 5A-FHE engine which had some fancy EFI system and larger throttle which pushed out 130 ? or something HP (can't remember the exact output figures). I've heard some people say the 5A-FHE is almost as good as the 4A-GE on the AE101s and that the engine is a good base for tuning (well for a Toyota power plant at least). The AE91 had front discs with rear drums, softer suspension, etc...
So the other components such as the gearbox is the same? Does that mean the 5A-F can be swapped with a 4A-GE or GZE without changing the gearbox? What are the other parts required? Btw both are FWD right?
  • Author
The AE92 came with the C52 gearbox and I think the AE91 came with a C50 gearbox (I say that only because most 5A engines came with it...). Not entirely sure about he mating of a C50 gearbox with a 4A-G engine...
  • 1 month later...
How's the progress Mr. iRage?
  • 6 months later...
  • Author
Okay...I know a lot o updates are due....but not today I am afraid.
So a quick question...the power steering rack is leaking oil. Now the mechanic wants to replace it and surprise surprise..none of the usual parts shop carry it. So the only solution (atleast for now) is to rebuild it. Having checked the web the old fashioned rack is somewhat serviceable. My question is..does anyone know of a mechanic/garage who actually knows something/anything about rebuilding the rack ?
  • 1 year later...
  • Author
Does anyone know the latest regulations regarding Engine swaps ?ย
I have been hearing rumors that the upto 500cc capacity increase has been scrapped and the new engine has to be the same capacity of the original engine the car came with.
Any truth to this ?ย
Even if it is true, I am presuming it applies only to new engine swaps...
Since I am not in SL its a bit hard to get info directly from RMV...
  • 2 years later...
  • Author
Wow...it has been 3 years since anything was stated here....on the plus side...nothing much has happened with the car except for a few things here and there....
So here is a recap...
When I got it:
The previous owner had installed a 7A-GE engine built with a 4A-GE blacktop head and converted the AT to a T50 5-speed.
WHAT I HAVE DONE SO FAR:
Engine:
UPDATE : Stock 4A-GE Blue top which I got from a friend in Japan off his low mileage car which he crashed :)
UPDATE : Cooling plate and AE86 washer fluid tank
- Installed the Fujitsubo exhaust the previous owner gave me with the car
- WHAT I AM PLANNING : Get a custom WEPR exhaust system that is more subtle and quiet....
Brakes/Clutch
- UPDATE : T3 braided brake lines (to be installed)
- AE86 pedal box
- AE86 master and slave clutch cylinders overhauled with Toyota overhaul kit
- AE86 brake booster and master
- AE86 front calipers completely overhauled with Toyota overhaul kit
- Dixel disks and brake pads
Suspension
- FRONT: Techno Toy Tuning coilovers custom built with KYB adjustable dampers and TRD springs with CUSCO camber plates.
- REAR: TRD adjustable short stroke dampers with TRD racing springs
- AE86 Front lower strut bar and CUSCO upper strut bar
- AE86 Rear under carriage strut bar (custom fabricated on to AE85 chassis)
- Replaced all suspension bushes with stock AE86 Toyota bushes
Body and Electricals
- Complete strip down and repaint
- New bumper signal/parking indicator lenses
- Swapped existing Levin coupe lights for Trueno coupe lights
- Installed an AE86 trunk lead garnish
- Installed new pop-up light motors
- Pop-up light control relay and pop-up relay plus interior wiring harness off of an AE86
Interior
- Redid the old style AE85 seats
- New light and wiper switches
- New AC switch panel
- Replaced lower dash components
- New panel clips, etcโ€ฆ
- AE86 meter cluster and housing...
- Clock and clock garnish
Tires and Wheels
- WHEELS: (Actual) RS Watanabe B-types. 14x7 rear and 14x6.5 front
- I canโ€™t remember what the tires areโ€ฆall I can say is I like the old style chunky wheel look of the AE86
  • Author
and after the bulk of the work has been completed...
No photo description available.No photo description available.No photo description available.No photo description available.No photo description available.No photo description available.Image may contain: 2 people, car and outdoorImage may contain: car and outdoorNo photo description available.
This was taken minutes before I went for a drive and the front wheel came off sending the car skidding...thankfully nothing broke :)ย ?ย No photo description available.
My Labrador decided to creep under the car and bite the steering rack..
No photo description available.No photo description available.No photo description available.No photo description available.No photo description available.No photo description available.No photo description available.No photo description available.No photo description available.
Oh yeah...I did put in a TRD short shifter too...
  • Author
The ECU was dangling at the back of the center console...so again..dad had gotten a bracket made and stuck it behind the carpet :)
image.png.c8dac6bffed67151b7a233ccaaaf7987.pngimage.thumb.png.29c6b6a421b310329bb32ce34f8824cf.png
When the car was taken to an AE85 Meet-up a few weeks ago...
The car looks gorgeous bro, congratsย
@iRage Car looks incredible.I can't fathom how pleasurable would it be to drive something old school like this compared to modern Mundane Toyotas we see on the Road today.
Wow! Wow! Reminds me older build threads.. superb way to finish the year and Congratulations!!ย โ˜บ๏ธ
18 hours ago, iRage said:
This is indeed a sight for sore eyes! WOW!ย  There's something charming about 80's and early 90's cars - the very linear-ness and the interior that reminds me of VHS players,Walkmans, Nintendo and the Terminator ?
